[MK7] Android chinese fiesta mk7 |
Velocity86
Wysłany: 9 Sty 2020, 08:53 [MK7] Android chinese fiesta mk7
hi forum,
sorry if i wrote first in english but i came from italy,
I purchased a Chinese-made Android stereo, it is installed as a replacement for the system monitor on the dashboard.
my car has the gray pin with 14 pins
the Android stereo instead, a black 24-pin plug from the June 2010 version, a canbox and a connector for the system monitor (7 pin utilizzati).
I started to connect the monitor plug, the stereo turns on, the steering wheel controls work, but the stereo always remains on, even with the car completely off, also no information is available such as open doors, automatic climate, and the central button does not is more enlightened.
for the 24-pin plug instead I wanted to follow the tutorial scheme "retrofit dab stereo on a prefacelift mk7" but the images are no longer available.
can you give me advice on how to proceed to solve these problems?
thank you very much for your help
| Ukryta Wiadomość: | Jeśli jesteś *zarejestrowanym użytkownikiem* musisz odpowiedzieć w tym temacie żeby zobaczyć tą wiadomość --- If you are a *registered user* : you need to post in this topic to see the message --- |
Wiek: 46 Dołączył: 23 Maj 2004 Posty: 12110 Skąd: Konstantynów
Wysłany: 9 Sty 2020, 23:45
| Był jakiś czas temu ktoś kto miał podobny problem, jak pamiętam, znaczy radio nie reagowało na instalacje auta,,, |
AndyDeBuger
Wysłany: 23 Lut 2021, 13:27
| Czy nikt nie jest w stanie odpowiedzieć? |
